Ac is not cooling properly.Very minor cooling.Filters are also clean
Why is my voltas spilt ac not cooling properly? Checked the filters which is clean.
Это хороший вопрос?
Счет 4
6 Комментариев:
Yes it clean
из
The model is fresh
The compressor doesn't start
из
@omarharidy Make and model for your AC? What have you checked? What does it do? Need more history.
из
نعم لدي مثل هذه المشكلة تماما المراوح تعمل وبكفاءة جيدة جدا والتبريد ليس جيدا الفلاتر نظيفة وتم تعبئة الغاز سابقا منذ وقت قريب
из
== Ac is not cooling properly.Very minor cooling.Filters are also clean ==
из
Показать ещё 1 комментарий
Добавить комментарий
3 Ответов
@juhipandey you did not tell us how the fan is running or even if it is turning on. If everything is as it should be, check the condenser coil. Make sure that it is clean and not full of debris. Clean it if needed. After that you will need to have to check the refrigerant and to make sure that is is fully charged. If you can tell us the exact model, we can hopefully find more information about the charge pressure and volume.
Был ли этот ответ полезен?
Счет 0
You'll need a technician to check and refill the refrigerant if it's low. This is a common issue in older units or if there’s a leak.
Счет 0
The AC is not cooling properly. The cooling is very low even though the filters are clean. Possible causes could be low refrigerant, a dirty condenser coil, a problem with the compressor or outdoor fan, or a faulty sensor. Please have a technician inspect the AC and check the refrigerant level, compressor, and outdoor unit.
Счет 0
Добавьте свой ответ
Juhi Pandey буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 2
За последние 7 дней: 12
За последние 30 дней: 44
За всё время: 1,112
