The first generation Audi A4 debuted in October 1994. The 1995-2001 A4 was built on the Volkswagen B5 platform.
My car engine RPM is fluctuating
Это хороший вопрос?
Счет 0
Добавить комментарий
1 ответ
Greetings Dillip,
The first thing I would do is check for vacuum line leaks and do a Throttle Body Adaptation.
  1. Disconnect battery for 30 mins.
  2. Reconnect
  3. Turn key to on for 15 secs ( You will hear clicking as the adaptation is going on ).
Start engine
If it doesn't improve, check again for vacuum leaks. - If no vacuum leaks can be found. Scan the car with an OBD scanner and check the O2 sensor.
Report back with the results and let me know.
Cheers!!
Moe
Был ли этот ответ полезен?
Счет 0
Добавьте свой ответ
DILLIP GADANAYAK буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 1
За последние 30 дней: 16
За всё время: 208
