Четвертое поколение iPhone. Ремонт прост, но дисплей должен быть заменен в сборе с сенсорным стеклом. Версия GSM; 8, 16 или 32 ГБ памяти; модель A1332; в Черном или Белом цвете.
2431вопросов Показать все
Speaker in private calls does not work, but does on loud speaker
I replaced my screen and now my phone speaker does not work. People on the other end of my calls cannot hear me at all but if I put them on loudspeaker, then they can hear me. What is the cause of this problem? Also, voice recorder does not pick up my voice either.
Это хороший вопрос?
Оценка 1
Добавить комментарий
2 Ответов
Выбранное решение
Sounds like your microphone may be faulty/upon reassembly you have not installed it correctly or damaged it.
In the iPhone 4 there are Two microphones
- One on the lower left (iPhone facing Frontwards)
- One in the top left (iPhone facing Frontwards)
The other port on the bottom right of the iPhone is for the speaker. Now the speaker also acts as a microphone however only activates when the phone is put on loud speaker, hence people being able to hear you when activated.
Circled in Red is the Main Microphone, circled in Blue is the connection ribbon responsible for the iPhone recognising the microphone along with the Speaker and several other parts.
So now that we know that the ribbon (circled in blue) is working as the speaker produces sound, the problem now lies with the microphone itself.
When you reassembled your iPhone, when replacing the speaker assembly you may have pushed the microphone out of place, try taking a look at it to see if the small rubber piece covering the microphone is situated correctly.
If it is then take a very close look at the ribbon itself to see if any small tears are visible. Let me know how you go.
Hope this helps!
Martin
Был ли этот ответ полезен?
Оценка 2
I have the same problem with iphone 5, where is the 3rd mic on the front of iphone 5? Is the screen protector covering it ok?
Оценка 0
Добавьте свой ответ
chasereinis будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 2
За всё время: 7,075
