The Motorola Droid 2 (A955) is the fifth phone in Verizon's Droid line.
Can the motherboards be swapped out?
My phone screen stopped working the blacklight turns on and I had it repaired and they said it's a problem with the motherboard and not the LCD ribbon. So my question is can the motherboard be swapped for a new one?
Это хороший вопрос?
Оценка -1
Добавить комментарий
Ответов (2)
Выбранное решение
If you're asking if you can replace the motherboard from your Droid 2 with another Droid 2 motherboard, the answer is yes. The only thing you'll have to keep in mind is that anything you had saved to your phone's internal memory will be gone. If you're asking if you can take the motherboard from a different model of Droid, the answer is unfortunately no.
Был ли этот ответ полезен?
Оценка 0
1 Комментарий:
yeah i was asking about swapping a droid 2 motherboard with another droid 2 motherboard, thank you for your answer!
из
Where can i buy a Motorola droid 2 global mother board?
Оценка 0
Добавьте свой ответ
Paul будет очень признателен(а).
Статистика просмотров:
За последние 24 час(ов): 0
За последние 7 дней: 0
За последние 30 дней: 8
За всё время: 795
