Четвертое поколение iPhone. Ремонт прост, но дисплей должен быть заменен в сборе с сенсорным стеклом. Версия GSM; 8, 16 или 32 ГБ памяти; модель A1332; в Черном или Белом цвете.
2376вопросов Показать все
Вопрос закрыт
Why isn't my iPhone powering?
Here's the story. I changed the mid-plate on friday and everything went well. On saturday, I reopened it but when I popped the battery, I saw a little spark. I was scared, and like I thought, it wouldn't power on ... But I plugged it in the wall and it worked again flawlessly. But here's the deal : Tonight I was installing Zagg shield (screen protector). Maybe 10 minutes afterward, I answered a text, placed my phone down and when I was wondering why I had no answer, I noticed my phone was dead. Thought it was the battery, but nothing was showing. Tried plugging it in the wall but still no luck. Checked the battery using a checker and it shows the battery has power. Something happened though : Maybe 15 minutes ago, I though my phone was fixed because the white Apple appeared. But it got stuck there for 5 minutes, tried hard reseting and now nothing works...
TL;DR
My phone isn't powering. What could be the problam and how can I fix it ?
Update
Could the solution used in the installation of my Zagg screen protector cause a problem inside the iPhone ? Like a short or something ?
Update
Any other solutions I could try out ? stuff I could check ?
Это хороший вопрос?
Оценка 0
1 Комментарий:
Is it still absolutely dead or does the Apple show? How much power does your battery show? Tried a hard reset yet? Have you tried to let battery charge?
из
Добавить комментарий
1 ответ
I have found it near impossible to actually kill an iPhone. But then again I also believe that nothing is impossible. A sort of contradiction there. Try removing the Mainboard from the phone and leaving it out for a couple of hours, the longer the better. If possible at least 24 hours. A full discharge of the whole phone will usually solve most annoying and strange problems such as yours.
I recently had a similar issue but kept the restore process going till even itunes wouldn't even acknowledge the phone as being connected. I removed the board and put it aside. After 48 hours I got around to having another go at it, once I put the board back in I got life. I did not even have to restore it, as it worked like nothing had happened.
I always do similar thing with any household appliance including my P.C. when they play DUMB. Pull the plug from the wall, let it sit for a minute or two to let all electrons to dissipate from the Capacitors and then plug back in. Strange as it may sound but at least 9 times out of 10 it works like new. The discrepancy of 1 is when you let the smoke out (Fried).
Good luck. I have yet to brick an iPhone or even see one. Except for terminal death by car and intentional damage of the Logic Board, snapped in two.
Был ли этот ответ полезен?
Оценка 0
1 Комментарий:
I tried this, I tried hard reset, tried taking all of the components out of the pohne (up to buttons and stuff). I tried hard reset, tried plugging it in for 12 hours ... Nothing seems to work ... Any way I can test if the logic board is defective ?
из
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 4
За последние 30 дней: 4
За всё время: 486
