maintain soldiering gun tip
what can l use to clean my soldering gun tip
Это хороший вопрос?
@shingirayic3632 make and model of your soldering gun? How much debris do you have on it? After all, it's a hot air gun you are inquiring about and there really should not be a lot of debris from using it. All I use on mine is a nylon brush and a cloth to wipe the nozzle clean. Bottle cleaning brushes work the best for my nozzles.
Был ли этот ответ полезен?
If you have a soldering Iron or gun (not a hot air system) then it gets into the flux you use and making sure you’ve kept the tip tinned properly.
Before shutting down your iron re-tin the tip. Cleaning your tip can be tricky! I use a cellulose sponge and distilled water as the minerals in the water can damage the tip.
Gun tips are a bit fragile as the electrodes meet up with a block of Nichrome which heats up and is the functional tip. Unlike an iron which has a sealed capsule withe the metal tip receptacle wound with Nichrome wire and often encapsulated with ceramic. Which can take a bit longer to heat but are stronger for the given size. The thin pencil irons can be damaged with too much force and as the tip is a softer metal you can bend it if not careful.
За последние 24 часов: 0
За последние 7 дней: 2
За последние 30 дней: 9
За всё время: 221
