Выпущен в 2021 году Номер модели: LS32AM700UUXEN
How to fix strange vertical scan lines on my Samsung M7 smart monitor
Hi,
This is my first post on this forum.
Recently, I have experienced an issue on my Samsung M7 smart monitor where strange vertical lines have appeared (See attached images).
I have no idea as to what could have happened to cause this problem.
Firstly, it does not appear to be a problem with any inputs (i.e., HDMI inputs) as the issue seems to be native to the screen itself.
I have tried unplugging all HDMI connections to the monitor, as well as leaving the monitor unplugged for a long period of time before powering it on again.
I have also tried resetting all settings on the device to no avail. The built-in trouble-shooter simply recommends to speak to Samsung about repairs. However, I would much prefer to resolve this issue myself (if possible) before I resort to the Samsung repair route.
If anyone has advice, fixes, or any suggestions it would be greatly appreciated.
Thanks,
Gman_Origin
Это хороший вопрос?
Счет 0
1 Комментарий
Hello Bro,
I have this exact problem. how did you resolve this? pls reply.
Thank you!
из Поделиться
Добавить комментарий
1 ответ
Наиболее полезный ответ
Not much you can do except replace the LCD in many cases :-(. Open it up and see, if you see a LTN panel from Samsung it will be pricey and likely total out the monitor but if it has the AUO panel they tend to be cheaper but generally not by a large enough margin to spare them. This is often the driver/TAB board having an issue.
If the iDP cable looks bent up or you want to try replacing it that sometimes works, but I would say 7/10 times the panel is bad with this issue. Also depending on the resolution the cost of a major repair will total it instantly, but this is primarily only 1080p (FHD) and 1200p (FHD+) - 1440p is getting there but 4K sometimes can be done economically.
Был ли этот ответ полезен?
Счет 2
Добавьте свой ответ
Gman _ Origin буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 12
За последние 7 дней: 45
За последние 30 дней: 69
За все время: 492
