The JBL Tune 510BT headphones are lightweight, cordless headphones. They have earmuffs that swivel in and out for storage and can be extended or shortened depending on the user's preference.
Headphones turn off when I rotate the right side
Whenever I rotate the right part then the headphones turn off, however once I put turn it back over my ears it turns on again and reconnects to my device. It also flashes red while charging. Could the problem be with the hinge/battery?
Это хороший вопрос?
Счет 0
Добавить комментарий
1 ответ
Yes, the battery is on the right side and the wires to the other side are just audio for the speaker.
If only one side goes dead, it is the connecting wire. If both sides die, it would be something loose on the battery side.
Click JBL Tune 510BT above for disassembly instructions.
Был ли этот ответ полезен?
Счет 0
Добавьте свой ответ
Kaiser Ahmed буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 5
За последние 30 дней: 28
За всё время: 399
