Простая в использовании 35-мм зеркальная фотокамера с ручной фокусировкой. Номер модели X-370.
pressure plate looks a little tad pressed in on bottom after dusting
Will this affect the X-370 performance? I bought this used in 1999.
Это хороший вопрос?
Счет 0
Добавить комментарий
1 ответ
Выбранное решение
As long as the film pressure plate is still fully connected to the rear cover and square when it fully seats wedging the film you should be fine. Make sure there is no dents or scuff marks on the plate.
Был ли этот ответ полезен?
Счет 1
2 Комментариев:
Thanks so much for your answer. There is a dent at the bottom of the plate where it connects to the base. But it is all connected. Can it be repaired? Or should I buy a new body. One is available on Amazon.
из Поделиться
Dan, I tested the camera after inserting new batteries. The plate was undamaged. The screen over which the film glides was pressed in a bit at the bottom but after testing the camera just now, all is well. It all appears to be fine. The camera needs a good cleaning. Thanks much!
из Поделиться
Добавьте свой ответ
Frederick Imbimbo буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 2
За последние 30 дней: 15
За все время: 305
