Wife put gas in oil on toro ext 1550 zero turn mower
Ok so my wife put gas in the oil, and I did a oil change on it, and put what I thought was enough oil in it and it started but then started smoking a little so I turned it off right away, I filled the oil back up to where it was supposed to be a couple days later but it kind of sat a few days by then (because I discovered I needed a new battery) so I got the battery put it in and the fly wheel pops up to try to start it but it just kind of clicks and won't start. If I open the arms and try to turn over the key it turns over, but it grinds my flywheel gear pretty bad anybody know what's going on with this thing? Did I seize it up running it for a short amount of time without enough oil? Is the gas still in the oil and maybe do another oil change? Appreciate any suggestions
Это хороший вопрос?
Счет 0
1 Комментарий:
Can you pull spark plug(s) and turn over the engine? This may blow out any raw gas and oil while examining the plug(s). A tablespoon of oil into the cylinder(s) will help piston ring sealing. Turnover the engine again, without plug(s). Clean and dry plug(s) for reuse and try starting again.
из
Добавить комментарий
