Обновленная версия iPhone 3G с более высокой скоростью обработки. Ремонт этого устройства схож с iPhone 3G, и требует простых отверток и инструментов для вскрытия. Модель A1303; 16 или 32 ГБ памяти; с Черной или Белой задней пластиковой крышкой.
1961 Questions Показать все
Touchscreen works badly after installing new front panel
(Iphone 3GS 16 GB)
Hey,
i removed my broken touchscreen few days ago and installed a new one, using the instructions on ifixit.com. At first sight it looked like everything was working but then i found out the bottom part of the touchscreen doesn't react. The upper sector does react, but not even nearly as good as my original one before ( even in broken condition).
I wonder what's the reason...
Guess it may be hard to analyze the problem without seeing the phone but If i'd demaged something just as the ribon cable 2 would the touchscreen work partly just as it does ?
I used a quiet cheap front panel so could this be the only reason for the faulty ?
Would be so great if you'd tell me your expections, because i just don't know if it would make sense to buy a high quality panel and install it.
Thanks!
Это хороший вопрос?
по рейтингу 0
Добавить комментарий
iPhone Battery Fix Kits
Only $29.99
Buy Now
Only $29.99
Buy Now
2 Ответов
Наиболее полезный ответ
The only times I have had this issue either:
- The connector wasn't fully engaged and just needed popping off and re-seating
- Small tear in the cable for the connector
- Bad part
there is a slim chance that the connector on the logic board itself was damaged in the original incident but I think I've only seen 1 phone with this issue and I put it down to a DIY fix gone wrong.
Был ли этот ответ полезен?
по рейтингу 2
Комментарии:
Lena, sounds like a bad digitizer. Contact your vendor and see if they are going to replace the one you have.
от
Definitely sounds like a bad digitizer to me. Or just the ribbon connector, worth checking if it's popped on properly.
по рейтингу 1
Добавьте свой ответ
Lena будет вечно благодарен.
Просмотр статистики:
За 24 часа: 0
За 7 дней: 0
За 30 дней: 0
За всё время: 479
