MacBook Air 2020 doesn't see battery / does not charge
Hi all!
So I've got a Macbook Air 2020 Retina Intel version that only boots whenever the power is connected (USB-C 30W original charger), (it is very slow and throttled then though, but that's probably because of lack of power).
I thought it was because it hadn't been used for 6+ months and the battery would be dead. So I went ahead and changed the battery with the one iFixit offers along with the guide they provide: Замена аккумулятора MacBook Air 13" (начало 2020 г.)
Everything was done quite easily. But the result is, unfortunately, still the same: it doesn't run on battery and also does not charge the battery. It doesn't show a battery icon in the top bar either (while the appropriate box for it is checked in the menu).
I've installed Coconutbattery and this is the result:
Does anyone know what else I can do? I've rechecked the battery cable a few times, but it really is connected properly.
I've done a SMC reset by following this video: https://www.youtube.com/watch?v=aM0TAJDm...
Not sure what else I can do. Would love to hear anyone's thoughts :-).
Update 13:55:
The battery cable wasn't plugged in far enough apparently! So it runs, YAY!
I've added pics of how it was connected and after I pressed a little harder, feeling a 'tick' as well.
New coconutBattery stats attached as well. Seems very old? Let's see how it will perform :-).
Это хороший вопрос?
2 Комментариев
Thank you! Thank you! Thank you! Your update with photo about inserting battery connector all the way made my day. I had the same happen to me. Thanks to you I was able to get it recognized and in working order. I appreciate it very much!
из Daniel M
@danielm27915 Haha thanks for the kind words, very glad it helped you out! Enjoy your MacBook and have an amazing day!
из Roel
