My girlfriend’s MacBook it’s working
Is here a solution for this problem?
My girlfriend’s MacBook has the same problem, did the same things mentioned at the chosen solution but unfortunately without success. The MacBook has alot of emotional value and it would be nice if it could start working again.
thanks alot
Это хороший вопрос?
Счет 0
2 Комментариев:
Is the system even booting up? What is the color of the MagSafe cords LED is it Amber or Green?
из
We need more details in order to give you repair advice. Is the device able to power on at all? If it can power on, what exactly isn't working? If it can't power on, there are a number of things that could cause that (e.g., failed battery, failed charging board, failed charger, liquid damage, etc). The first thing you could try though is an SMC reset. Good luck!
из
Добавить комментарий
