Руководства и информация по ремонту пылесосов Hoover.
Hoover UH71250 WindTunnel Green Indicator Light is Always On
I have a Hoover UH71250 WindTunnel Vacuum Cleaner. The Green Indicator Light is Always On, showing its Always Clean, even when the vacuum cleaner is very dirty after months of use.
I thought the sensor was jammed so I clean the dirt cup, cyclonic filter, rinsable filter, and hepa filter, it is always Green after 6 months of usage. I'm wondering if the sensor is broken. Let me know if there is an easy fix, or I will buy another $200-300 vacuum cleaner.
Это хороший вопрос?
Счет 0
Добавить комментарий
1 ответ
The sensor is dirty. Clean the sensor by removing the bag, pull the handle back and turn on for 20 seconds. Don’t use it on the floor while running. Replace with a clean bag.
Был ли этот ответ полезен?
Счет 0
1 Комментарий:
Hi, Thank you, I'm not sure I understand
I have a vacuum like this, https://www.youtube.com/watch?v=JQ94HQrZ...
the bag is not a throw away bag, but a permanent plastic canister.
So I unattached the bag, pulled back the retractable handle so it was parallel to the floor, and placed it on the ground for 20 seconds, and then held it midair for 20 seconds. It didnt see to fixed it yet,
Where did you receive this solution from by the way? I did not see it on the Hoover website
из
Добавьте свой ответ
MarkAlex буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 17
За последние 30 дней: 34
За все время: 378
