Seventh generation of iPad, released September 25, 2019, available in 32 or 128 GB models. Model Number A2197.
iPad 7 Not showing battery percentage or charging when booted
Basically i decided to revive my 7th gen ipad from the dead, everything worked fine till it went in a boot loop
I tried using itunes on my pc which didnt work, then i used 3utools to flash it but couldnt go past 19 percent, then randomly it revived and i was so glad
But when i go to the control centre it doesnt say the percentage, so i go to the settings and the battery percentage was enabled
Bare in mind the ipads in charge but doesnt say it is
A while after using it it shut down saying the charge finished, i know the charger i used worked so i recharged the ipad and it turned on but after a while it turned off again
My problem is not the boot loop but rather the fact that when its out of power it charges but when its on it cant charge
I bought the ipad in 2020 its been around exactly 4 years
Это хороший вопрос?
Счет 0
Добавить комментарий
1 ответ
Наиболее полезный ответ
Judging by the information you've given, this seems to be some sort of problem with the firmware not picking up that it's being charged, which to me sounds like something relating to your NAND in the device has either been removed or has been corrupted.
Был ли этот ответ полезен?
Счет 1
7 Комментариев:
so what do i replace to fix this?
из
If it's possible for you to use iTunes to reflash the entire device and factory reset it, do that. Not sure there's much you can replace hardware wise to fix this, since the issue seems to be originating in the software.
из
when i plug it in the pc it doesnt even show up
из
Check the charging port and make sure it's cleaned out. Sometimes you may get enough buildup of dust to make it where the charging port is unable to be properly used.
из
the charging port is fine when its in recovery mode it shows up but when its not it doesnt and when its in recovery mode it doesnt restore
из
Показать ещё 2 комментариев
Добавьте свой ответ
Berat Bayir буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 1
За последние 30 дней: 4
За всё время: 95
