The XV50 Camry was introduced on 23 August 2011, and began U.S. sales in September 2011. The interior received a major restyling, while the exterior received all-new sheet metal and more angular styling.
The vehicle is vibrating when the engine is running
Engine vibrating
Это хороший вопрос?
Счет 2
Добавить комментарий
1 ответ
@brighthovorna you are not providing enough information. We would need to know the exact year, engine size, transmission type etc. This could be as simple as a disconnected vacuum line to as complex as issues with the fuel or ignition system. I would suggest to get the OBDII scanned. That way you will at least have a good starting point. Let us know what codes that showed.
Был ли этот ответ полезен?
Счет 0
Добавьте свой ответ
Bright Hovorna буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 1
За последние 30 дней: 7
За всё время: 164
