Why isn't my replacement battery holding a charge?
I replaced my battery per the instructions. However my laptop is not recognizing the battery and only turns on when plugged in. When unplugged, the battery shuts off immediately.
Это хороший вопрос?
Это хороший вопрос?
Did you make sure to plug in the battery data cable? See Step 11 of this guide. That ribbon cable needs to be properly installed and connected to the battery and the logic board in order for the battery to be usable. You may need to transfer it over from the bad battery if the new one didn't come with one. Good luck!
Был ли этот ответ полезен?
За последние 24 часов: 0
За последние 7 дней: 1
За последние 30 дней: 6
За всё время: 72
Can you please install this gem of an App CoconutBattery and post a snapshot of the Apps main window posting it here so we can see things.
из DanJ
