Steam-контроллер Valve, выпущен 10 ноября 2015 года. Модель 1001.
Right Bumper Not Working Anymore: Plastic Piece on Trigger Mount Broke
After about 8 years using the Steam Controller, the right bumper stopped working. It no longer clicks audibly when pressed, even feels that it's floating over the button when fully assembled. I took it apart and found this piece broken off.
That rectangular flange in the red box in the photo needs to be attached to the trigger assembly, but that one narrow path is a point of failure. I don't think I can expect to glue it back on and have it working perfectly fine again. Can I get some advice on finding the part I need to replace this? If it's a 3D print, can I print only part of the base that I need, or do I need a whole new trigger mount assembly, and then move the trigger, spring and bolt there?
Это хороший вопрос?
Счет 0
Добавить комментарий
1 ответ
Выбранное решение
I found the 3D print file of the replacement part, gave it a try with Polycarbonate from PCBWay's 3D Print and Delivery service, and got it installed in my controller, working well so far. I made a guide on the procedure here.
Был ли этот ответ полезен?
Счет 0
Добавьте свой ответ
Damian буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 7
За последние 7 дней: 11
За последние 30 дней: 23
За всё время: 354
