GSM iPad 2 with 16, 32, or 64 GB of storage, and a Dual Core A5 Processor. Model Number A1396. Repair is complicated and requires heat and prying.
151вопросов Показать все
Вопрос закрыт
Frame bent at volume button
Ipad was dropped & bent frame around volume button. The button now is in a bind & is not moveable. The volume is on the center of the screen at all times.
Это хороший вопрос?
Оценка 0
Добавить комментарий
2 Ответов
I've read you can use steam or a heat gun to soften plastic and straighten out a bend, though, I've never personally tried myself. Could be an option for you to utilize, keeping in mind, not to damage any parts with excessive heat or moisture. I would make slight adjustments as to not overdo it.
Is there any way you can upload an image to get a better look?
Был ли этот ответ полезен?
Оценка 0
This exact thing just happened to me. Any solutions?
Оценка 0
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 0
За всё время: 706
