Model A1312 / Mid 2011 / 2.7 & 3.1 GHz Core i5 or 3.4 GHz Core i7 Processor, ID iMac12,2
Thermal paste or Liquid Metal for my gpu?
Im about to install a new gpu for my 27" mid2010 iMac, so i have to put new thermal paste (or LMetal) to the memory chips and the gpu chip of the board. What are my options to choose, and would u place LiquidMetal? Knowing the the gpu gets over heated might LMetal be a good option?
Update (12/26/24)
What is the best thermal paste and pads i can use for the stock gpu? Is Arctic-MX6 the best option for paste i can use?
Especially regarding pads, im afraid to select, cause they might be too thick... i need all the help i can get from u guys!
Update (01/20/25)
Hi Dan, i was referring to chips like the ones i show with the red arrow. They have already had some thermal putty on them, thats what caused me to wonder.
Это хороший вопрос?
Счет 0
6 Комментариев
Personally, I think liquid metal is a little overkill for a GPU in an almost 15 year old computer. Thermal paste is also much safer than using liquid metal.
из
@junaaydshaikh i was thinking that since those iMac stock gpus had an overheating issue, using LMetal would be the best way to lower the heat.
In what way do u think that LMetal is overkill ?
из
@genik im sorry, i completely forgot that gpus were replaceable and on the mac board itself. i was subconsciously thinking he was going to use an egpu wired into the board.
из
@genik - Per your image the larger R56 block devices are inductors and the eight smaller SMD devices I believe are voltage regulators. Neither access the GPU heat sink block as such there is no thermal binding needed (no thermal paste or pads needed and you don’t want them covered otherwise the air flows will be interfered with.
из
All those were covered with thermal putty by Apple.,, but u say they shouldnt have been... right?
из
Показать ещё 1 комментарий
Добавить комментарий
3 Ответов
Наиболее полезный ответ
Liquid metal is very conductive. When applied incorrectly, it can cause short circuits in your system. Considering the size of components in mainboards, it only takes a very small amount of liquid metal to bridge connections and cause a short circuit. Also, liquid metal can get into very small gaps like under memory chips and GPU cores. It is very hard to clean.
There are already plenty of cases of motherboards and GPU's damaged or rendered completely unusable because of leaking liquid metal.
I strongly suggest you just use thermal paste. Look for good quality thermal paste and thermal pads.
Был ли этот ответ полезен?
Счет 1
2 Комментариев:
Noctua NT-H2 gets good reviews so does thermal right TF-9. I recommend you do some more research and compare some of the leading recommended thermal pastes.
As for thermal pads, they come in different thicknesses. You have to choose the right thickness for your intended application. There are also many reviews of top thermal pads, you can choose from those brands.
из
Thanks Winky. If use pads, how will i know what is the right thickness?
из
Just like water, it will seek a lower elevation. Given how the iMac logic board is setup on its edge the Liquid Metal TIM will slowly drip down wetting the circuit board damaging it!
I’m sure you would like the system to last as such don’t use any Liquid Metal TIM on your systems that either have a vertical mounted logic board or a laptop which often is stored in a vertical configuration. Horizontal logic boards it makes sense and don’t let it sit in a vertical stand!
As for what to use the GPU it’s self uses the same TIM as your CPU any non conductive or capacitive TIM will do. We all often try to push the limits thinking the testers of things review makes out this TIM is better than the next. While that can be true in some cases, often times today the TIM’s argued about are so close in performance it really makes little difference. Think it this way are you racing your car on the Indi 500? There I can see how a 1/4 of a degree makes a difference.
OK, but what about the VRAM chips? Apple started off using pads and to save time they jumped to a gapping TIM, frankly it’s not as good as the more modern pad materials. For fit I often recommend using some cut up business cards to create a feeler gage to judge the thickness. For most boards 1.5mm is needed. Just make sure to use a slightly larger piece so the entire VRAM chip is covered.
So while we’ve focused on the physical aspects, you should also install a good thermal monitoring App like TG Pro so you can keep an eye on your thermals and if need be pump up the fans cooling.
Update (12/26/24)
Here’s an image of a MXM board marked up
The yellow needs thermal paste, the red needs the pads
Счет 1
30 Комментариев:
Excuse my non native Eng, but what does TIM mean :-)
If i get it right, you don't agree on using LMetal, but u are ok for using 5mm Thermal Pads, did i understand correctly?
из
@genik - Sorry, I should have been clearer,
TIM = Thermal Interface Material
Liquid Metal is a different kind of paste, it is not intended to gap a space. Pastes are intended to be squeezed between the given chip and the heatsink, it basically fills the micro voids of both surfaces so more heat can be transferred across when the two surfaces are pressed touching each other.
Pad’s are a filler to again transfer the heat but as the surfaces are not directly touching need to fill a void. They tend not to be as effective as a paste or even some TIM sheets which are very thin. So far pastes are the better for touching surfaces.
Pad’s are tricky! As over time they shrink a bit (hence why you need a slightly larger piece to cover the chip).
из
Even with the best of setups of transferring the heat between the chips to the heat sink, the dumping of heat is the bigger issue! The fan’s speed to transfer the heat into the air stream and how clean the fan blades and the heat transfer fins are become the gating factor.
Think it this way you have a stream of water filling a small tank at some point the tank becomes full and unlike our example here there is no place to spill the heat over the tanks wall, so the current heat prevents new heat to enter into the heat sink. So getting back into our model this tank needs a hole in it for the water to spill out of the size of the whole then sets the limit of the tank before it over flows. Which once again can’t happen in a heat sink setup. So we either need to enlarge the hole or forcefully drain the water (heat here) we can’t alter the heat sink, but we can force more heat out.
из
@danj so to cut things short... plz correct me if im wrong... your suggestion is, neither to use LMetal nor Thermal pads. Just use a good Thermal Paste in both GPU chip and Ram chips?
из
@genik - No on Liquid Metal as the iMac logic board running horizontal will allow it to drip.
The CPU and GPU chips (the big boys) use a good thermal paste.
The GPU board also holds VRAM chips that are near the GPU chip. These are at a different elevation from the GPU chip as such standard thermal pastes won’t work! You need a gapping paste or what I think is the better is a physical thermal pad. You need to cut the pad material up so each VRAM chip has its own and you want the pad to be a bit larger than the chip.
из
Показать ещё 25 комментариев
The job of thermal paste is to fill in holes in the joining surfaces so you have a flat thermal conductive surface. You can't see the holes.
I dislike thermal pads because they are a LOT thicker than properly applied thermal paste. It takes just a thin spread by a razor blade.
Pads are used for manufacturing expedience.
Счет 1
1 Комментарий:
“Pads are used for manufacturing expedience.“ Not always, Pads are often used when the profile of the chips are at different heights to the heatsink.
The heat dissipation between the devices also needs to be considered. This gets into the natural flows of heat and just like water we take the least obstructed pathway. Here the hotter GPU chip could dump to much heat quickly into the VRAM chips before the heatsink had enough time to shed the heat buildup off the primary heatsink block
By there nature pads are less efficient that paste as the thickness of the material gets in the way of good transference of the heat. Whereas paste when properly applied fills in the pores of the two surfaces and mostly squished out leaving a few microns of thickness and as the material is also highly effective in heat transfer it’s the ideal material.
It all comes down to using the correct material!
из
Добавьте свой ответ
genik буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 3
За последние 7 дней: 22
За последние 30 дней: 65
За всё время: 413
