The Siamons Fogger model 200-620810 is a mold removal fogger that atomizes a mold control solution into a fine mist for even surface application. The mold control solution is meant to eliminate existing mold and prevent mold growth.
Can I use this on a Laptop
I can’t use a mold Removal Fogger on a Laptop, can I?
(Found some little dots of mold on my Laptops Fan when trying to clean it and removed them with an anti-Static desinfectent. No the less I’m sure I didn’t get all of it)
Это хороший вопрос?
Счет 0
Добавить комментарий
1 ответ
Выбранное решение
@nutzer39892 nope. You are going to get plenty of humidity on the inside of the laptop which will create trouble (corrosion, short circuit etc) with your motherboard. You will have to disassemble your laptop, remove the motherboard and clean everything separately.
Был ли этот ответ полезен?
Счет 2
Добавьте свой ответ
Professional буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 2
За последние 7 дней: 6
За последние 30 дней: 13
За всё время: 155
