iPad 7th Gen A2197 - 0.47A Draw, Won’t Turn On - Need Advice
Hi everyone!
I’m working on an iPad 7th Gen that won’t turn on. When I connect it to a charger, it draws 0.47 amps. However, if I disconnect the battery, it draws 0 amps.
I’ve watched a few videos in YouTube (mostly from NorthridgeFix) about this 0.47–0.5 amp draw issue, where the problem seems to be a short on the board. In those cases, the iPad still draws that current even with the battery disconnected. However, in my situation, the current drops to 0 when the battery is disconnected.
I’ve also checked the board using a thermal camera, but nothing seems to heat up. I tried measuring some random caps to look for shorts, but I haven’t found anything obvious.
I’m feeling a bit stuck—does anyone have suggestions on what else I could check or test?
Thanks in advance for your help!
Это хороший вопрос?
Счет 0
Добавить комментарий
