Firewire target mode not recognizing target disc
Okay....one mac with flashing question drive running on power supply, other mac running on battery...did firewire target mode and began to copy system to bad drive with superduper....firewire target mode recognized bad drive but the battery died and had to stop...now I have swapped DC boards and have both macs running on power supplies....:)....yay! Two macs!!..but one still has flashing question mark and now good mac does not recognize bad mac in target mode....aarrggh...any suggestions on how to 1) get good to recognize target firewire drive. 2)possibly boot from USB minidrive with copied system folder on it, since dvd drive is non-functional on bad mac, or 3)hmmm...?
Thanks again for all the great support!!
Это хороший вопрос?
2 Комментариев
Aha! After a few times got it to recognize...it has the system library on it and when I use disk utility it says 'no repairs necessary'...I understand it should be a 160gb hd but it only shows that it is a 74.5 gb drive(?)...I believe it still has the flashing question mark when I try to boot normally....suggestions on how to repair or get it to boot normally?
из joe
In superduper there is no 'clone' command. I can only copy my 'harddrive' to the target disc...is this correct?
из joe
