Getting too hot after sim card insert
iphone4s 32gb white . it getting too hot when i put the sim card insert . it only remain in searching mode and battery is draining very fast like in 1 min 6% drained and get too hot from battery jack and the near by and middle bezel also from below the sim card . before it was working fine. it was dropped on the floor but working after accident . it worked for approx 6 days. now showing this symptom .
Это хороший вопрос?
4 Комментариев
My frnd checked the Battery terminals. He said this iphone is shorted. He checked some tracks it shows fully shorted . baseband ic is getting so hot while it uses the sim card. without sim card it running perfectly. anybody know where to start the checking of shorting ?
из SIMRAN
i got the same problem !!! on a 64 gig
из jimtsolakakis
not being funny simran, but why would a shorted battery give you problems when the sim is inserted? I'd be looking at antenna/sim problems as this seems to be when the problem starts. If sim is inserted but in aeroplane mode do you still get the drain?
из pollytintop
in aeroplane battery is not draining . when i turn off the flight mode. it remains in searching always and getting hot.
из SIMRAN
