This is one of South Africa's biggest smartphone manufacturers.
Why I can't update my systems phone
Why my phone is not updating my system
Это хороший вопрос?
Счет 5
6 Комментариев
Hi @preciousve27935
What is the model name and number of the phone?
из
Trouble shooting can you update my phone applications
из
i cant download sotfwer in mobicel phone
из
When I off it and ON it back it will keep going off and ON 5 time
из
I have forget my password
из
Показать ещё 1 комментарий
Добавить комментарий
1 ответ
Наиболее полезный ответ
If you're unable to update your Mobicel phone's system software, here are some possible reasons and solutions:
1. Check Internet Connection
Ensure you have a stable Wi-Fi connection (preferably, not mobile data) when checking for updates.
2. Not Enough Storage Space
Go to Settings > Storage and check if you have at least 2-3GB of free space for the update.
Delete unused apps, clear cache, or move files to an SD card if storage is low.
3. Battery Level Too Low
Many phones require at least 50% battery (or need to be plugged in) to install an update.
4. Software Update Not Available
Some Mobicel models may not receive regular updates.
Check Settings > About Phone > Software Update to see if an update is available.
5. Server or Region Restrictions
Sometimes, Mobicel releases updates in phases based on region.
Try using a VPN to connect to a different region and check again.
6. Corrupted System Update Files
If you've downloaded the update but can't install it, go to:
Settings > Apps > System Update > Clear Cache & Data, then try again.
7. Update Manually (If OTA Update Fails)
If the OTA (Over-The-Air) update doesn't work, you can try manually flashing the update:
Visit the Mobicel official website (or XDA forums) to check if there's a firmware update for your device model.
Use SP Flash Tool (for MediaTek) or Odin (for Samsung-based models) to manually install the update.
8. Contact Mobicel Support
If none of the above solutions work, reach out to Mobicel customer support for assistance.
Let me know your Mobicel phone model and the
error message you’re seeing, and I can help further!
Был ли этот ответ полезен?
Счет 1
1 Комментарий:
I'm straggling to block ads on my phone please help
из
Добавьте свой ответ
Precious Velemani буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 1
За последние 7 дней: 18
За последние 30 дней: 93
За всё время: 1,247
