MBA battery charge drain with no activity
Yesterday I've noticed a strange thing with my MBA 13.6 M3. I usually when at home or don't need to move, I leave the magsafe attached and it will. be usually green. When I come back yesterday from work, I've noticed the green was orange and the battery was at 80%, but whan I closed the lid beafor go to work in the morning the battery was at 100%. I've waited until the battery comes back to 100% during this night and today I found the battery at 87%!
Why this occur?Is there something wrong with my MBA?
Update (02/14/25)
Это хороший вопрос?
It maybe slightly lower than the likely normal capacity for a new laptop, but this can be about normal. How long does it take to fully drain from a full charge?
из livfe
I'm not sure about but it will mantain the charge for 1 day. Iusually leave the magsafe attached when possible so I've just used 33 cycles of charge. My forst MBP mid 2014 after the same time of usage had the battery a lot used but with more charging cycles
из B1P
@ziobru ! day is way to less.... @danj thoughts?
из livfe
@livfe it depends what usage I do. but I think it's ok for a laptop.?
из B1P
@ziobru Yes, if your on it most of the day then you can expect the battery to drain faster, but if not used and the laptop was in sleep mode then overnight around 2% or a little more maybe.....
из livfe
Показать ещё 1 комментарий
