Repair and service information related to the ResMed AirSense 10 CPAP machine. Also known as the ResMed Air10.
What voltages power the blower motor?
I have two good CPAP blower motors for the ResMed AirSense 10 with their attaching wire plug. I don't want to plug them into a CPAP machine, I want to use them as independent blowers.
Problem: I can't find anywhere what voltages are applied to the Black, Yellow, and Orange wires. Does anyone know?
Это хороший вопрос?
Счет 0
Добавить комментарий
1 ответ
Hi @drkenrich
Is there any product information on the blower motor at all e.g. make and model number or voltage(V)/current(A) values?
Usually with DC motors the black is earth or (ground), red is power supply (in your case it may be orange) and the yellow wire (3rd wire) could either be a temp sensor lead or rpm lead.
Connect an Ohmmeter between the orange and black wires and check for a resistance reading. If you get one (don't know what value) it most probably is the motor winding.
Then connect the meter between the black and the yellow. If there's a resistance reading try using a hair dryer and warm the blower up. If the resistance value changes then it's a temp sensor. If it doesn't change or if there's no resistance measurement then try manually spinning the blower blades (if possible) and check if there's pulses seen on the meter when it spins. If there are most likely it is a hall effect sensor that indicates rpm.
Just what I'd try if you can't find any information when searching online for the make and model number of the blower.
Был ли этот ответ полезен?
Счет 0
Добавьте свой ответ
Ken Rich буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 4
За последние 30 дней: 21
За всё время: 169
