The Mi-T-M Pressure Washer CBA-3504, powered by a 389cc gasoline engine, is designed for residential and commercial cleaning of exterior surfaces. This page provides repair and detailed information about the pressure washer's features, including its maximum pressure of 3500 PSI, flow rate of 3.7 GPM, various spray nozzles, and its dimensions of 30" x 24" x 40".
no pressure coming out of the wand
why do I lose pressure when coming out of wand
Это хороший вопрос?
Счет 0
Добавить комментарий
2 Ответов
You say that you're "losing pressure." I presume there is some pressure at first and it comes and goes.
Some possibilities are:
  1. Air in the pump. When you connect the water to the washer, be sure there is water flowing to it (no kinks in the hose, water is turned on). Without starting the washer, hold down the trigger on the wand until water sprays out in a steady stream (no air spurts!). Only then should the washer be started.
  2. Occasionally, there might be air in the supply hose which, when it reaches the pump, may cause a loss of pressure. If this lasts for more than 10-15 seconds, I would shut off the pump and bleed more air as above.
  3. It may be something in the gun assembly. Here's a link to a parts supplier that may have some useful info for you ; https://www.ereplacementparts.com/mitm-c...
  4. If none of these steps work, and you have ever run the washer without water or you have stored the the washer in an unheated area where the temperature falls much below freezing, the pump may have sustained damage. But if either of these were the case, I would suspect that you would have no pressure at all.
Был ли этот ответ полезен?
Счет 0
Take the gun off the hose. Open up the nozzle at the end of the gun as wide as possible. Get a long sewing needle and poke into the exit hole. Could be a tiny grain of sand blocking it. Then pour water down the hole to wash out the sand. Reconnect to the hose and try it. I've fixed MANY powerwashers doing that simple cleaning.
Счет 0
Добавьте свой ответ
shaun буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 3
За последние 7 дней: 22
За последние 30 дней: 46
За всё время: 289
