13-дюймовый MacBook Pro, выпущенный в мае 2020 года, оснащен четырехъядерными процессорами Intel 10-го поколения Core i5 и i7 и интегрированной графикой Intel Iris Plus. (Модель A2251/EMC3348 с четырьмя портами Thunderbolt 3)
MacBook Pro 13" 2019 Four Thunderbolt ports won't turn on
My 2019 13' MacBook Pro with four thunderbolt ports will not power up. First it would barely hold a charge. Then I was able to only use it plugged in; however, the other day while using it while plugged in it just shut down. No warning. I haven't been able to get it to start up since. I've tried the SMC reset, different charger, different outlet but it seems totally dead. I've looked at the guide to replace the battery but the time/cost doesn't seem worthwhile. Is there anything else to try?
Это хороший вопрос?
Счет 0
Добавить комментарий
1 ответ
Usually we would all suggest to install coconutBattery to see the batteries status, but seeing that it no longer powers up at all then it suggests that their is an issue along the power rails on the logic board which would require a skilled technician with the know how and available parts to replace. Replacing the battery itself isn't impossible when following the guides carefully, but it is still worthwhile as these units are still worth more than the the cost to repair. At least I would search around for a local repair service to get their price and opinion and go from there with your decision.
Был ли этот ответ полезен?
Счет 0
Добавьте свой ответ
Hank Madison буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 1
За последние 30 дней: 7
За всё время: 115
