Второе поколение Kia Soul, представленное на автосалонах в Нью-Йорке и Франкфурте в 2013 году, создано на базе концепта Kia Track'ster.
replace oxygen sensor upstream kia soul 2016 2.0
replace oxygen sensor upstream kia soul 2016 2.0L
Это хороший вопрос?
Счет 1
1 Комментарий
@nick Kia's are right up your alley. You got something to help @josephjose18271 out?
из
Добавить комментарий
1 ответ
Наиболее полезный ответ
The first thing here is to get the car scanned, and NOT buy parts immediately (see the callout I made on this). Given that you know it's the sensor, I will assume you had this done. It's always a P code for emissions, so any basic scanner will do the job here if you decide to buy your own. Anyway, look for a P code related to the emissions for 02 sensors to confirm directly.
If the code returns, it's generally on the exhaust manifold with Hyundai/Kia engines. I found some photos from a 2016 Forte which should match given the engine is shared between Hyundai/Kia and used in multiple cars:
I wish I could find a better photo, but start there. You should be able to reach it yourself, but you may want to lift the car from the bottom and do it that way - the engine bay access is a big problem in the Soul for these parts. Make sure to use a good set of jack stands and put at a minimum, 4 under the car. If you use something like an air jack put good jack stands in place as a safety net.
Был ли этот ответ полезен?
Счет 2
Добавьте свой ответ
joseph joseph буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 2
За последние 7 дней: 7
За последние 30 дней: 22
За все время: 459
