Repair guides for smartphones manufactured by LG that use the Android operating system (OS).
Phone starts to turn, freezes on screen.
My phone is an LG rebel 3 LTE. I have had it a little over 5 years. This morning I turned it off. When I turned it on again, it starts as it always did, but freezes about halfway through, on the tracfone screen. From there, nothing works.Hold down the power button, nothing. Hold down the power and volume down bottom, nothing.
I took out the battery and it goes off. Put it back in and try again. Same result. Took out the battery and SIM card. Put the battery back in and try again. Same thing, starts up but freezes on tracfone screen.
Is their any hope for this phone? I get that its a cheap phone that I got 5 years out of. My issue is I have a bunch of downloads, mostly audio, that I don't want to lose. I'm guessing the SIM card is alright and I could use that in a new phone and keep my contacts. But I'd lose the downloads which I stupidly didn't back up when I knew this was an eventual possibility.
Again,for those far more tech literate than I, is this a hopeless situation? Is the phone likely shot? Thanks.
Это хороший вопрос?
Счет 0
7 Комментариев
Just to be clear, I took the battery out. With the battery out, I held the power button down for 30 seconds. Put the battery back in and turned it on. Same thing with one exception. Something that happened right before I saw your answer when I was trying for the 15th? Time today.
The difference is this. When I first power on I see a couple LG screens then the tract one freeze screen. Last 2 times, after a couple minutes I get an android is starting up screen then the LG screens then the tracfone screen where it goes no farther. It has done that twice while I type this. To be clear, I saw that Android starting up screen the last 2 times I tried powering up from scratch. And the first time was before I tried your suggestion.
Just trying to give you as much info as clearly as I can.
из
jayeff, thanks for the replies. To answer your questions. The battery charges when I plug the charger in. The battery charging indicator is on. I mean when the phone is off. When I originally said hold power and volume down buttons and nothing, I wasn't trying to clear anything. Just trying to get out of that frozen tracfone screen. I had seen that suggestion in a general internet search before I saw this forum. I wasn't thinking clear cache or anything like that. I have no SD card in the phone. Have never used one in the phone.
I said earlier 2 LG screens. There is only the 1. Says life's good, something like that. When I first power on, you see that screen for a good 15 seconds then the tracfone screen. When the tracfone first appears, for a couple seconds, there is some background sound, maybe music, sort of a greeting, I guess. That has always been there since I got the phone.
I said after a few minutes I would see the android is starting screen,, which has green color in it.
из
Is there a character limit? Couldn't type more. After the android is starting screen, I see the LG screen, but only for a couple seconds this time, then tracfone, but no sound this time. And that is the cycle every I don't know how minutes. The only way to do anything is to take the battery out. And then I start over.
I tried your suggestion. From scratch, instead of just pushing the power button, I pressed both that and the volume down button. As soon as I saw the LG screen I
released the buttons. Waited a second or two and pressed the power button. I see no recovery screen. Everything is the same as if I started with just pressing the power button only. I have tried it 3 times.
из
@lancer63579
Try the recovery method again but this time when you see the LG screen and you release both buttons, press the power button as soon as possible and don't wait and check if that gets you there.
из
Just wanted to say the reason I answer in comments is the board said I should when I did my first reply. Thanks for your patience in answering multiple times. I tried your suggestion and sadly no luck. I released the 2 buttons as soon as I see LG and push just the power button pretty much as quickly as I can. Maybe a second later. No recovery option I see just the usual that I get every time. Tried 3 or 4 times, same result.
Not that I imagine this matters, but I was right before. 2 LG screens. First has Android powering at the bottom. Second has Qualcomm something at the bottom. Between the 2 of then 15 plus seconds and then the tracfone screen.
This is all started yesterday turning the phone off and then turning it back on. I have done this numerous times in the past. I don't do it every day, but it sure isn't rare. Last summer I had sort of the same thing happen with a tv 12 years old. Startup would be normal for the first 10-15 seconds and would just freeze and go no farther.
из
Показать ещё 2 комментариев
Добавить комментарий
2 Ответов
Наиболее полезный ответ
Hi @lancer63579,
Try removing the battery and then press and hold the power button operated for 30 seconds then release the button.
Reinsert the battery and check it it starts and works OK.
If it does, backup your data first just in case
Update (03/15/25)
Hi @lancer63579,
Does the phone indicate that the battery is charging OK when the charger is connected to the phone?
Also presumably none of your data was stored on the SD Card in the phone (if it has one)?
Not sure if you were trying to wipe the cache partition after the phone had been turned on when you said "....Hold down the power and volume down bottom, nothing." but did you try doing this from when the phone is off?
If this is not what you were trying to do, try wiping the cache partition¹ and check.
With the phone turned off, press and hold the Volume Down and Power buttons, (both together).
Release both when the LG logo appears, then press the Power button again to enter recovery mode.
When in Recovery mode, use the volume keys to navigate through the menu options to Wipe Cache Partition then press the Power button to confirm.
Do not select Wipe data/factory reset as this will erase all your personal data from the phone.
¹ The cache partition stores temporary data and if there's corrupted data stored here, it could affect the operation of the phone
Был ли этот ответ полезен?
Счет 1
It sounds like your LG Rebel 3 LTE is experiencing a software or firmware issue, possibly due to a corrupted system file or a failed update. Since the phone freezes on the TracFone screen during boot, it’s likely stuck in a boot loop or unable to complete the startup process. Here are some steps you can try to recover your phone and potentially save your data:
1. Try a Forced Restart
- Remove the battery, wait 10 seconds, and reinsert it.
- Hold down the Power button and Volume Down button simultaneously for 10-15 seconds. This may force the phone to restart and bypass the freeze.
2. Boot into Safe Mode
- Turn off the phone completely.
- Press and hold the Power button until the LG logo appears.
- Once the logo appears, release the Power button and immediately press and hold the Volume Down button.
- Keep holding the Volume Down button until the phone boots up. If successful, you’ll see "Safe Mode" in the bottom-left corner of the screen.
- In Safe Mode, third-party apps are disabled. If the phone boots successfully, you may be able to back up your data.
3. Perform a Factory Reset (Warning: This Will Erase Data)
- If Safe Mode doesn’t work, you may need to perform a factory reset. Note: This will erase all data on the phone, so only do this if you’re willing to lose your downloads.
- To factory reset:
1. Turn off the phone.
2. Hold down the Power button and Volume Down button simultaneously.
3. When the LG logo appears, release and immediately hold both buttons again.
4. This should bring you to the factory reset menu. Use the volume buttons to navigate and the power button to select "Yes" to reset.
4. Recover Data Using a Computer
- If the phone still doesn’t boot, you can try connecting it to a computer to access the files:
1. Connect the phone to a computer using a USB cable.
2. If the phone is recognized, you may be able to access the internal storage and copy your audio files to the computer.
3. If the phone isn’t recognized, try booting into Download Mode:
- Turn off the phone.
- Hold the Volume Up button and connect the USB cable to the computer.
- This may allow the computer to recognize the device.
5. Seek Professional Help
- If none of the above steps work, consider taking the phone to a professional repair service. They may be able to recover your data or repair the software issue.
6. Prevent Future Data Loss
- If you manage to recover your data, back it up immediately:
- Use cloud storage (e.g., Google Drive, Dropbox) for your audio files.
- Transfer files to a computer or external storage device.
- Enable automatic backups in your phone’s settings.
Счет 0
2 Комментариев:
I took the phone to a repair store. Guy told me that there was nothing he could do. I believe motherboard was the word he used. He couldn't fix it. Another question then. Poking around the internet, I see that there is software that can retrieve files from a dead phone. If true, can you give me some advice on this? Thanks.
из
I don't have an answer for you but the same thing happened to my LG Rebel 3 today when I try to turn it on it's stuck on the TracFone screen so I guess mine's not going to work either since you never had any luck with your phone coming back on. But if you have been successful I would really like to know good luck
из
Добавьте свой ответ
Lancer буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 4
За последние 7 дней: 6
За последние 30 дней: 41
За всё время: 655
