How to change the 02 sensors. Code shows a slow to respond error on 1.
How to access the o2 sensors, and can they be cleaned? Getting a slow response code.
Это хороший вопрос?
Счет 0
2 Комментариев:
What year RDX?
из
In addition to the year, it would help if we knew the exact trouble code you're getting.
из
Добавить комментарий
1 ответ
I don't believe cleaning is an option. Mostly, it wouldn't be worth the effort to try. Changing is easy once you can get to them. Remove the wire, unscrew the old one, screw in the new one, reattach the wire. Some cars have 2, or 4 if you have dual exhaust. The key is finding it and having the right articulated wrench to get to it.
Был ли этот ответ полезен?
Счет 0
Добавьте свой ответ
Trace буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 2
За последние 7 дней: 6
За последние 30 дней: 16
За всё время: 266
