Where is the spark plugs located on a 2004 cavalier Ls
where is the spark plugs located on a 2004 cavalier LS
Это хороший вопрос?
Это хороший вопрос?
James, the cover on top of the motor needs to be taken off. The one that says 2.4 or whatever you have. Remove the accelerator and cruise control cables (if you have cruise).
2. Remove the bracket.
3. Remove the 4 bolts that secure the coil.
Hope this helps, good luck.
Был ли этот ответ полезен?
If you cannot get the bolt off of the arm bracket just remove the wires that are clipped onto it, and bend it straight up. After you have replaced the spark plugs, bend it back into place and re-clip the wires...
You will also need a 'star' bit for three of the bolts you will need to remove.
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 0
За всё время: 9,077
