The iFixit Precision Bit Driver is an aluminum or plastic handle that fits 4 mm bits. Found in the Manta, Mako, Moray, Mahi, Minnow, Essential Electronics, Pro Tech and Pro Tech Go Toolkits from iFixit.
Larger driver in the MANTA kit the blue cap came off
The blue cap on the end of my larger driver for the manta kit came off. I tried to get it apart but was unsuccessful. And not sure howto get apart to fix it like the smaller 1/4" driver.
Is there a way to fix it??????
Это хороший вопрос?
Счет 0
Добавить комментарий
1 ответ
Yes you can reattach it! You can either ask Customer Service to replace the driver or you can fix it yourself. To re-attach it you can follow this guide How to Reattach the Cap on a 4 mm iFixit Precision Bit Driver
Был ли этот ответ полезен?
Счет 0
1 Комментарий:
The driver that the blue cap came off of is the larger driver in the manta set not the smaller precision driver. I've seen the videos and guides to repair the small one. But is there a way to repair the larger one without having to replace it? That's what im trying to find out.
из
Добавьте свой ответ
chev72nova буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 2
За последние 30 дней: 10
За всё время: 89
