The US version of the sixth generation Sonata was unveiled at the 2009 Los Angeles Auto Show, with sales beginning in 2010 for model year 2011. For the US market, the sixth generation Sonata boasted a direct-injection 2.4-liter four-cylinder engine.
How to replace starter in my hyundai sonata 2011 2.4L car
How to replace starter in my hyundai sonata 2011 2.4L car. Mechanic asking me $500 to 600
Это хороший вопрос?
Счет 0
Добавить комментарий
1 ответ
Наиболее полезный ответ
Disconnect battery first so you dont arc. Take off the engine cover, then remove air duct and box assembly; it should be 2 bolts for the duct and 2 bolts for the box, then undo the air intake tube at the throttle body and disconnect vacuum lines. Unbolt the throttle body from the intake, but dont disconnect the cooling lines or you'll have to bleed the cooling system. Probably should remove the map sensor as well, its just an 8mm bolt holding it in, no need to unplug the connector, just get it out of the way so it doesnt get damaged. Remove the intake bracket, the starter is right behind it. Unplug the connector and use a 12mm to remove the nut on the power wire. Undo the starter bolts at the bell housing and starter can be wiggled out. Install in reverse order
Был ли этот ответ полезен?
Счет 1
1 Комментарий:
@sonykumar besides the great instructions provided by @brooklyn123 here are the Sonata Starterworkshop instructions
из
Добавьте свой ответ
Sony Kumar буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 4
За последние 7 дней: 18
За последние 30 дней: 85
За всё время: 970
