Mac doesn't recognize HD.
At the beginning the mac started to slow down so I decided to reinstall the OS, when I did it kept running slow so I did it again. when it started up a question mark appeared on the screen, I looked on the internet and said the HD was broken so I changed it for another one that I had at home. when I turn on the mac the question mark appeared again. so I inserted the installation dvd, the dvd runs but when I have to chose the destination HD theres no HD to chose from.
now, is the HD that I installed broken? or could it be another problem.
Thanks
Это хороший вопрос?
Счет -1
1 Комментарий
What was the full name of the replacement hard drive and what is it's history?
из
Добавить комментарий
2 Ответов
Выбранное решение
Sorry, I though Josh was going to answer this. You have to Boot from your system installation disk, go to the second page pull down menu to Utilities -> Disk Utility and format the drive before trying to install a system on it.
Был ли этот ответ полезен?
Счет 2
1 Комментарий:
good answer +
из
I've never worked with one of these iMacs, but here's my suggestion:
Could it be that the harddrive needs jumpers? I had an old PowerMac G3 that would exhibit the exact same symptoms as your iMac. I was able to fix it by setting the jumpers correctly.
If the above does not help, just sit tight a couple minutes- Mayer will be along to save the day! He's pretty good with diagnosing internal problems.
Счет 0
2 Комментариев:
No jumpers needed on a SATA in Macs ;-)
из
Haha, my bad. I've never dealt with SATA.
Should I delete my answer since it's not helpful?
из
Добавьте свой ответ
Fernando Garcia буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 0
За последние 30 дней: 4
За всё время: 1,875
