Xiaomi Mi 11 Lite 5G NE — это смартфон среднего ценового сегмента от компании Xiaomi, выпущенный в сентябре 2021 года. Устройство оснащено 6,55-дюймовым AMOLED-экраном, основной камерой на 64 Мп, сканером отпечатков пальцев, расположенным сбоку, аккумулятором емкостью 4250 мАч и процессором Snapdragon 778G.
How to change the battery of Xiaomi MI 11 lite 5G NE?
How to change the battery of Xiaomi MI 11 lite 5G NE? The battery backup of this phone has been dropped by 50% after heavy use of 3 years. Where can I get the original battery?
Прокрутите эту тему, чтобы найти подходящее место для этого комментария. Затем нажмите "Прикрепить комментарий к этому сообщению", чтобы переместить его.
@drnishant since iFixit does not yet have a specific guide for this, use the one from here. It is written in Spanish so use a browser that does the translating for you (if needed)
Original batteries are only available from the OEM and they do not sell directly to the consumer. There are lots of good aftermarket batteries for this phone, just purchase from a reputable seller
While you work on your phone, take lots of pictures. Once you are done with it, take those pictures and create a guide for iFixit. That will help the next person that has a device with the same issues as you do. It's easy and fun to create these guides. https://ifixit.com/Guide/new The iFixit community will appreciate this.
It sounds like you're looking to replace the battery in your Xiaomi Mi 11 Lite 5G NE, and you're also wondering where to find an original battery. Replacing the battery in modern smartphones can be a bit tricky as they are often not designed for easy user replacement.
Here's a breakdown of how you might go about it and where to look for a battery:
How to Change the Battery (General Guidance):
Keep in mind that this is general advice, and the exact steps for your phone model might vary. It's always best to consult a specific guide or video tutorial for the Xiaomi Mi 11 Lite 5G NE.
Power Off Your Phone: This is the first and most crucial step to avoid any electrical damage.
Remove the SIM Card Tray: Locate and remove the SIM card tray.
Heat the Back Panel (Potentially): Some Xiaomi phones have a glued-on back panel. Applying gentle heat (using a hairdryer on a low setting) around the edges can soften the adhesive. Be careful not to overheat it.
Pry Open the Back Panel: Use a thin, plastic opening tool (spudger or guitar pick) to carefully pry open the back panel. Start at one edge and gently work your way around. Be extremely cautious, as forcing it can damage the back panel or internal components.
Remove Screws: Once the back panel is off, you'll likely see screws securing a plastic mid-frame or metal shield that covers the battery and other components. Remove all these screws.
Disconnect Flex Cables: Before you can remove the battery, you'll need to disconnect any flex cables that are attached to it. These are usually small ribbon cables with delicate connectors. Use a plastic spudger to gently lift the locking mechanism and detach the cables.
Remove the Old Battery: The battery itself might be held in place with adhesive. You can try gently prying it up with a plastic tool. Be careful not to puncture or bend the battery, as this can be dangerous.
Install the New Battery: Place the new battery in the compartment.
Connect Flex Cables: Reattach any flex cables that were connected to the old battery.
Reassemble: Put the mid-frame or shield back in place and secure it with the screws. Carefully align and press the back panel back onto the phone until it clicks into place.
Insert SIM Card Tray: Put the SIM card tray back in.
Power On and Test: Turn on your phone and check if the new battery is working correctly.
Where to Get an Original Battery in India:
Finding an "original" battery can sometimes be tricky, as manufacturers often don't sell them directly to consumers for DIY repair. Here are some places you can explore:
Authorized Xiaomi Service Centers: This is your best bet for getting a genuine battery and professional installation. Search online for authorized Xiaomi service centers in your city or region in India.
Xiaomi India Website/App: Sometimes, official spare parts might be available through their website or mobile app. Check the support or accessories section.
Reputable Third-Party Suppliers: Some well-known online retailers or local electronics stores might sell batteries that they claim are original or high-quality replacements. However, be cautious and check reviews and the seller's reputation before purchasing. Look for suppliers who specialize in phone parts.
Consider Professional Repair Services: If you're not comfortable doing the replacement yourself, you can take your phone to a reputable third-party repair shop that specializes in smartphone repairs. They may be able to source a suitable battery and install it for you.
Important Considerations:
Difficulty: Battery replacement in modern phones can be challenging and carries the risk of damaging other components if not done carefully. If you're not experienced with electronics repair, it's generally recommended to seek professional help.
Warranty: Attempting a DIY repair might void any remaining warranty on your device.
Safety: Be extra careful when dealing with lithium-ion batteries. Puncturing or mishandling them can lead to fire or explosion.
Given that your phone is 3 years old and the battery life has significantly decreased, getting a new battery is a good step. I would recommend starting by checking the official Xiaomi channels for service centers or genuine parts in India. Good luck!
2 Комментариев:
@vedangupad46680 while AI can be a useful tool for some things, us moderators here at iFixit do not feel it can be relied on as a sole authority for answers to repair questions. We would strongly request that you indicate that your answer is generated using AI so our users can judge the accuracy of the answer for themselves based on that knowledge.
