Инструкции по ремонту, поддержка и информация об устранении неполадок для первого 13-дюймового MacBook Air с процессором Apple M1 на базе архитектуры ARM (с 8-ядерным центральным процессором и 8-ядерным графическим процессором). Выпущен в ноябре 2020 года, имеет номера моделей A2337 или EMC 3598.
Important Data Recovery But Device is Broken
I had transferred some important videos from a trip onto my M1 Macbook air. However when i went to edit it shut down randomly. I couldnt turn it back on! It was wayyy past warranty so no Taking it to the apple store. The device is not working and not charging. Is there any way to recover data? Like no need to fix it (bc its too expensive) but just the Data
Это хороший вопрос?
Счет 0
Добавить комментарий
1 ответ
Выбранное решение
The SSD storage on these models is soldered onto the logic board, so if the unit is showing no signs of life then you will not be able to access the data that it is holding. Until the unit has powered on we cannot diagnose if the problem could be from a dead battery. It would need to be checked over by an experienced technician to see if there is some shorted circuit or other issue, that is if you didn't have the tools and know how to investigate the issue yourself. Sorry for the bad news.
Был ли этот ответ полезен?
Счет 0
Добавьте свой ответ
RyanJoseph буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 5
За последние 30 дней: 12
За все время: 177
