Nespresso Essenza Mini: Pump Runs non stop when plugged In, No Lights
Hi everyone,
I have a problem with my Nespresso Essenza Mini (Krups). As soon as I plug it into a 220V AC outlet, the pump starts running immediately and does not stop. It keeps pumping cold water continuously.
None of the indicator lights turn on or flash, and the machine does not respond to any button presses. It just keeps pumping until I unplug it.
So far, I’ve tried:
  • Plugging it into a different outlet
  • Checking for visible signs of damage or moisture
  • Power cycling (unplugging and plugging back in after a few minutes)
Nothing has helped. Has anyone seen this behavior before? Could it be a faulty control board, stuck relay, or something else?
Any advice or troubleshooting steps would be greatly appreciated!
Thanks in advance.
Это хороший вопрос?
Оценка 0
Добавить комментарий
