Более крупная модель ноутбуков MacBook Air от Apple, оснащенная двумя микрофонами и поддержкой Wi-Fi 802.11ac.
not sure what BATTERY replacement is good for this MacBook Air?
Hi everyone, I'm new here and know nothing about this sort of stuff.
My Macbook air does not work unless it is attached to a charger. Sometimes even whilst being charged, the battery is on red. I can't afford a new laptop and would like to replace the battery.
Can anyone advise me what battery is needed for the following Macbook air? Do 2014 or 2015 Macbook air use the same battery as the 2013 Macbook air model?
MacOS Big Sur
11.7.10
8gb 1600 Mhz DDR3
Serial Number: C02MG358F6T6
Thank you in advance.
Это хороший вопрос?
Счет 0
Добавить комментарий
1 ответ
Наиболее полезный ответ
A1369 & A1466 MacBook Air 13" Models 2010-2017 are using the same Model #A1377, A1405, A1496
Install coconutBattery to see the actual condition of your battery but I think your battery is at the end of its lifespan, but a good idea to double check nevertheless. (Take a screenshot of the report and post it in your question (edit question & add image) so we can confirm.
Замена аккумулятора MacBook Air 13" середины 2013 года
Был ли этот ответ полезен?
Счет 2
7 Комментариев:
@livfe thanks for your answer. I can't download coconut battery as my MacOs version is too old.
из Поделиться
@aishaot Scroll to the bottom of the CB website and you can get versions that are for older systems :) Your MB Air can support OS 11.7.10 Big Sur.
из Поделиться
@livfe thanks, I finally managed to download coconut battery. I've attached the screenshot on my post. Based on that info, what battery do u suggest I should get? tia
из Поделиться
@aishaot Go to finder (in prefs under locations select to show your device, then navigate to the system library folder and there should be 3 or 4 files .com.apple.power*, delete them and empty the trash, restart, and check CB again..... Batteries I have bought before were the A1405 if I remember rightly, strange it says poor condition yet 100%.... try the method stated before, also do a PRAM reset also.
из Поделиться
@livfe thanks. I think I'll buy the MacBook Air 13" (Late 2010-2017) Battery regardless, hopefully it is the right battery for the model
из Поделиться
Показать ещё 2 комментариев
Добавьте свой ответ
Aisha буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 2
За последние 7 дней: 5
За последние 30 дней: 43
За все время: 660
