Repair and disassembly guides for the Nintendo Switch OLED Model, announced and released in 2021.
Why does my switch have a black screen?
My switch OLED, will flash the Nintendo logo and then go black, if I hold power button for 30 seconds, and then plug it in it will show the battery icon, after letting it charge for some time, the icon shows full, but to get the battery icon to show, I have to unplug it and hold the power key for 20+ seconds and then plug it in for it to show. Not sure what the issue could be.
Это хороший вопрос?
Счет 0
Добавить комментарий
1 ответ
Наиболее полезный ответ
Hi William!
This could be a lot of things unfortunately. But it does sound like it’s having issues with the NAND or motherboard.
Since they are married to each other, it’s recommended to replace both of them (as set).
You CAN try to replace the NAND (small IC connected to the motherboard), but then you do need to re-programm, reflash it to make it work.
Please let me know what you want to try for yourself, then I can sent you some guides!
Был ли этот ответ полезен?
Счет 1
5 Комментариев:
I would replace both, where could I source the parts? Also would all memory be lost? Or is the hard drive separate?
из
Just realized that I can order right from here.
из
I don’t see the NAND, would it come attached to the motherboard that is listed?
из
The EMMC (NAND) is seperate and is connected on the motherboard it self. You can replace it, BUT, it’s married to the motherboard. So it won’t work if you just replace that part…
So, yes, when you replace it, the data is lost :(.
Here you can find the EMMC: https://www.ebay.co.uk/itm/316604799604
Guide (to see where it is connected to): Nintendo Switch Motherboard Replacement (in the very last step, you can see the part connected to the motherboard).
Regarding a new motherboard, I advise to contact Gamers Repair. Link: https://www.gamersrepair.com/
Their service is awesome!! And they do ship worldwide. Hopefully you can get the Switch working again!!!
из
@williamrey83719 sorry, just saw your last 2 messages. Yes, the NAND should be provided with the motherboard! So you can buy from here as well! Sorry for the late response!
из
Добавьте свой ответ
William Reynolds буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 6
За последние 30 дней: 44
За всё время: 339
