The threads inside the hole are damaged.
When I inserted the screw into the red-circled hole in the photo, I made sure to keep it perfectly vertical at a 90-degree angle. However, the thread inside seems to have been damaged.
The first few threads from the top — about 3 turns — appear to be deformed at a 90-degree angle, preventing the screw from going in all the way.
As a result, the screw gets stuck and cannot be tightened properly.
  1. "The screw is a P5 1.2mm type — could you tell me the correct tap size for the hole it fits into?"
  2. "Does the hole in that area go all the way through?"
Это хороший вопрос?
Счет 0
Добавить комментарий
1 ответ
It appears the bottom cover is not aligned to the screw stud below in the upper case frame as seen here.
So either the cover is not properly aligned or either the cover or upper case frame has become bent somehow. Review this guide for better images and screw sizes Замена нижней крышки MacBook Pro 16" 2019
Can you give us a bit more information on why I assume you popped the bottom cover off as that might offer us why this is not aligned.
Был ли этот ответ полезен?
Счет 0
Добавьте свой ответ
고정애 (당신의 정애) буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 1
За последние 30 дней: 7
За всё время: 96
