Представленный 28 сентября 2023 года, Raspberry Pi 5 является обновленной версией аппаратного обеспечения Raspberry Pi 4B.
Pi is not booting up
I connect ot to the power supply and it shows red light, (my pi camera was shorted and burnt a bit from since my pi is showing red light) it is not showing green light, fan doesn't spin and a minor current i feel when i turn it on any fix?
Это хороший вопрос?
Счет 0
Добавить комментарий
2 Ответов
troubleshooting steps:
  • See if a pc can recognize the device.
  • Reprogram the firmware
  • Check if the SD card is working properly
  • Check the voltage rails on the GIPO header pinout is found here
how to change boot mode and other pi hardware documentation is found here
Был ли этот ответ полезен?
Счет 0
@prasadgawas since this happened because "my pi camera was shorted and burnt a bit from since my pi is showing red light" you do want to go ahead and repair that damage. Anytime you have a shortened component you will have top replace it first and check all of the traces as well as other components which may have shortened out as well. Go ahead and post some good pictures of your Pi5 with your question so we can see what you see.
Since this is physical damage, no firmware update etc. will work for this
Счет 0
Добавьте свой ответ
Prasad Gawas буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 1
За последние 7 дней: 6
За последние 30 дней: 67
За все время: 721
