Why my water pump overheat and also not working after 20 minute start
Whenever I switch on it the water come only for 20 minutes and after that the device become extremely heat and then water stop
Это хороший вопрос?
Счет 0
Добавить комментарий
1 ответ
Your water pumps can be overheated and stops due to several reasons, check if you missing these things
  1. Dry running – No water in the source, causing motor to overheat
  2. Clogged inlet or impeller – Reduces flow, stressing the motor.
  3. Poor ventilation – Motor isn't cooling properly.
  4. Overload or faulty capacitor – Causes motor to heat and shut down.
Check your water supply if coming properly, clean the pump properly, ensure ventilation is there
Был ли этот ответ полезен?
Счет 0
1 Комментарий:
I check all these things but still getting this problem please help me out
из
Добавьте свой ответ
Arpit Dubey буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 1
За последние 7 дней: 8
За последние 30 дней: 40
За всё время: 320
