Инструкции по ремонту, поддержка и информация об устранении неполадок для первого 13-дюймового MacBook Air с процессором Apple M1 на базе архитектуры ARM (с 8-ядерным центральным процессором и 8-ядерным графическим процессором). Выпущен в ноябре 2020 года, имеет номера моделей A2337 или EMC 3598.
Ribbon cable cover screw broke
As if my luck couldn't get any worse this stupid screw decided to break somehow
how is this even possible??? Do I need it? The other screw is fine thankfully but what do I do about this one?
Update (07/29/25)
I'm cooked
Update (07/29/25)
Decided to use some electrical tape to tape it down, very very sketchy. But there's nothing else I could do at the moment, plus there's the other screw and that one works so I'm not completely cooked. Tested it and it works fine, for now but my gut says that something will happen soon.
Update (07/30/25)
I don't know if this is ok but I have no other options, is the emi shield even necessary? the undamaged screw makes sure it's at least on top of the connector, idk. Maybe there's a better tape I could use that would be better long term?
Это хороший вопрос?
Счет 0
Добавить комментарий
1 ответ
Наиболее полезный ответ
Taping it down is not going to help much in any way, I had this happen on a MBA 2018 model and I used one of these soft pads that comes with a 2.5" External drive caddie. It can stick to the top of the small plate and when you screw down the case it will sandwich it holding it in place. You may also need to apply a small double sided tape on the case to hold it secure on both sides.
Был ли этот ответ полезен?
Счет 1
2 Комментариев:
How do I know exactly what thickness I need to not potentially damage the board or something? Maybe it's better to use like a stronger tape?
из
@lyxres It is up to you. These are soft pads that can squash quite easily. Best option that comes to mind.
из
Добавьте свой ответ
lyxres буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 2
За последние 30 дней: 11
За все время: 212
