Speed Queen makes noise during wash cycle
Washer makes metal to metal grinding sound during wash cycle. Happens with medium to full loads.
Это хороший вопрос?
Счет 0
2 Комментариев
Hi @cliff93935
What is the model number of the washer?
из
Thanks for responding. Model # of washer is AWN432SP113TW04.
из
Добавить комментарий
1 ответ
Наиболее полезный ответ
Hi @cliff93935
Not sure but it could be either the upper or lower bearing.
Here's a video that may (or may not) help to check if they're OK or not.
If the bearing is the problem, the part number for the bearings in your model is 28944RP (supplier examples only).
Here's the service manual for your model and also a parts list that may also help. If another part is the problem, locate the wanted part in the list and note the part number shown for it. Search online for the part number only, to find suppliers that suit you best.
Был ли этот ответ полезен?
Счет 1
Добавьте свой ответ
Cliff буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 2
За последние 30 дней: 16
За всё время: 82
