Руководства по ремонту и поддержке электрических и бензиновых аппаратов высокого давления, также известных как мойки высокого давления.
Best way to handle stubborn outdoor grime with a pressure washer?
Hey everyone,
I’ve been working on cleaning driveways, decks, and patios with my pressure washer but I’m not getting the best results.
Here’s what I’ve tried so far:
  • Standard pressure-washing (2000–3000 PSI) with detergents
  • Letting surfaces air-dry overnight
  • Multiple passes with different nozzle angles
Still, some stains refuse to come off.
So I’d like to ask:
  1. Do you adjust PSI or nozzle type depending on the surface or how old the stains are?
  2. Any tips on prepping surfaces—like grit, cleaning solutions, or methods—that make pressure washing more effective without damaging the surface?
Thanks in advance for any advice!
Это хороший вопрос?
Счет 0
Добавить комментарий
1 ответ
Hey,
I frequently pressure wash, what i do for hard to get grime is use a mixture of Pool Chlorine, water and a Surfactant, the surfactant is basically just soap I use a brand called Surf (in Australia) its a 5in1 laundry liquid.
I get a pressure sprayer and mix about 3L bleach to 7L water with 1 cap full of Surf 5in1
Note: Pre-soak plants/grass with water as the bleach can kill them.
Be careful what soap you mix with the Chlorine because i believe theres a possibility to create a toxic gas.
Был ли этот ответ полезен?
Счет 0
Добавьте свой ответ
Dirtkiller буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 3
За последние 30 дней: 15
За всё время: 166
