Why is my computer randomly shuts down with a new battery?
Update (08/27/25)
This might be the reason. The design capacity should be 8700 mAh.
Update (08/27/25)
Это хороший вопрос?
Это хороший вопрос?
Could be overheating, loose connection, or even a power supply issue. I’d check temps and make sure everything’s seated properly. Sometimes it’s not the battery at all
Был ли этот ответ полезен?
@ramzenzaren - If the system is able to run a few minutes I would install this gem of an App CoconutBattery it will allow you to see more clearly the health of your systems battery. Take a snapshot of the Apps main window and post it here so we can see it as well.
A helpful tool is a USB-C power meter which you can place inline with your charger to monitor its power delivery.
Here's the guide to replace the battery MacBook Pro 16" 2019 Battery Replacement
Possible Reasons for this-
@rashmikand95190 - Please review the system details before dropping a generic AI? Generated solution. If this was a desktop then this would have been reasonable. As this is a laptop if fails to even deal with the issues it would likely have and a Mac laptop is different enough to a Windows system, in this case doesn't even have a BIOS chip or built-in power supply.
За последние 24 часов: 1
За последние 7 дней: 6
За последние 30 дней: 22
За всё время: 227
@ramzenzaren - Yes the capacity is not correct!
But I don't think that explains the random shutdown. Can you take one more snapshot this time after clicking on the Battery Info button so the battery info is seen.
из DanJ
Another thing that I failed to mention is that when it restarts it shuts down once I log in.
из RamZenZaren
