Brother MFC-L8650CDW not recognising toner cartridge
The printer was working perfectly until I replaced the set of colour toner cartridges. (I've been using compatibles, which have been working great).
When I inserted the replacements (same as previously used) the printer refused to recognise the Cyan cartridge (or any other cartridge) but the cartridge was recognised just fine in any other location. This indicates to me that the problem lies with the printer, not the cartridge.
Could this be a Brother ploy to get you to buy their vastly over-priced cartridges?
Any help on how to fix this would be greatly appreciated, as I'm stuck without the printer.
Прокрутите эту тему, чтобы найти подходящее место для этого комментария. Затем нажмите "Прикрепить комментарий к этому сообщению", чтобы переместить его.
2 Комментариев
@porpoise1983249 "Could this be a Brother ploy to get you to buy their vastly over-priced cartridges?" that is exactly what I was thinking as well. Let's see if our printer guru @nick has a solution for you.
This is the old chipless generation, so it's a much easier fix at least :-). Keep this unit until it needs major service and try and find a low meter printer that lacks the chips if you can, the chip printers can be a royal PITA with recognition issues. Brother doesn't explicitly pull an HP or Xerox*, but they are a little sensitive.
*Only a problem on pre Lexmarkified engines and floor printers with metered supplies. They just nag you briefly if it's flagged to run Sold supplies.
First thing I would check is the toner flag and make sure the toner isn't off balance - make sure it is set to "full" - use your yellow or magenta as a baseline, as those are full or barely dented. You want the gear to be in the full position as reusing a toner will trigger this unless you reset it on the gear/optical toner printers like the L6850. You can reset it if needed by removing the cover, pulling the spring back and forcing it back into the full position if the gear isn't at 100% capacity. I suspect the chip printers do not have this problem but until Brother lets us print on "empty" toner like HP, Lexmark and Canon I don't buy these - but on the other hand, I would take one in if someone gave me a gently used one for the sake of giving it a home where the repairs are viable.
If the gear is in the full position, check the ground points on the drum unit as well as the toner - if those are dirty, it causes a similar problem. Wipe it down with a microfiber cloth you can sacrifice (that is to say, one you can throw in the garage and never use on things like prescription glasses). If the toner didn't come with one, buy one on eBay or Amazon and add it. That will fix the problem if the toner didn't come with one or it is not happy with the one it has installed.
If neither of those work, it's usually a drum issue. It's a combined CMYK part so it's on the expensive end of the spectrum. If you can take it apart a bit or clean it I would go that route before spending that kind of money on a new drum unit.
3 Комментариев:
Hi Nick,
I'm scratching my head here as I don't understand this bit:
"First thing I would check is the toner flag and make sure the toner isn't off balance - make sure it is set to "full" - use your yellow or magenta as a baseline, as those are full or barely dented. You want the gear to be in the full position as reusing a toner will trigger this unless you reset it on the gear/optical toner printers like the L6850. You can reset it if needed by removing the cover, pulling the spring back and forcing it back into the full position if the gear isn't at 100% capacity."
@porpoise1983249 I did research it more. This might be an early chipped and geared printer. The chip on the toner might be bad. See if you can reset the gears and replace the chip.
2 Комментариев
из oldturkey03
@oldturkey03 This one has the chipless toner so there’s ways to try and recover it.
из Nick
