Repair guides, support, and troubleshooting information for the 2022 13-inch MacBook Air, featuring Apple's M2 SoC. Released on July 15th, 2022 and identified by model number A2681.
Why is my keyboard not working but my trackpad works just fine?
For a while now Ive had issues with my keyboard becoming unresponsive randomly, even sometimes it works for seconds and the caps key will light up green as i press it. After seconds then it'll stop working, it went a while working after I reset the software and reset the computer completely, but then when the laptop died and I went to charge it... the keyboard stopped working again, the backlight still illuminates and the trackpad works fine. I'm not sure if a whole new keyboard needs to be installed or whether it could be someone as small as the flex cable. Please help.
Это хороший вопрос?
Счет 0
Добавить комментарий
1 ответ
First off the keyboard and the trackpad are each unique circuits. I do believe the keyboard is connected via the interconnect cable between the two logic boards. So this could be a loose connection or a liquid spill which is effecting the connection.
Apple now publishes repair manuals for the newer M series systems which might help you narrow down the issue. Here's the manual MacBook Air (M2, 2022) Repair Manual if we jump to the Mac Laptops Troubleshooting Input/Output Issues see if the diagnostic process leads you to an answer.
Был ли этот ответ полезен?
Счет 0
Добавьте свой ответ
Joel Lux буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 2
За последние 7 дней: 7
За последние 30 дней: 53
За всё время: 243
